jp104
Feb 21, 2019Tutor
Help changing Orbi to AP
Recently purchased an Orbi wifi extender and set it up. It worked great for 3 days then I started getting the dreaded 401 error. After searching on the net for this error I see that the way most peop...
- Feb 21, 2019
You can set up the Orbi if you disconnect it from the ISP modem.
Factory reset the Orbi and skip the setup wizard. Once your in, go in to the advanced settings and change the Orbi to AP mode. Then you can connect it to the ISP modem.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jp104 wrote:
Thank you! I think I have that double NAT thing going on. I'm away from the router now while at work so I'll have to try what you posted later on tonight. Also do you know if there is a way to set the Orbi to AP while doing the set up? I may just have to uninstall the whole thing and try again from scratch.
Feb 21, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Review option #3...
jp104 wrote:
Recently purchased an Orbi wifi extender and set it up. It worked great for 3 days then I started getting the dreaded 401 error. After searching on the net for this error I see that the way most people fixed it is to change the Orbi router to AP. I tried to login to the router while on the orbi network using http://orbilogin.com but it still gives me the same 401 error. I've done this from multiple devices and PCs with no luck thus far. I also tried to log in remotely from the app.
So at this point I cannot log into the orbi router to change to AP mode. Is there any way to do this from the orbi app? I can't see any options to enter advanced mode from the orbi app. Any assistance is much appreciated!
Internet provider ATT Uverse fiber
jp104
Feb 21, 2019Tutor
- CrimpOnFeb 21, 2019Guru - Experienced User
I understand that the "double NAT" causes specific problems. Considering that the default configuration for most ISP devices is "router" and the default for Orbi is "router", there must be a lot of users who have no problems. My Orbi has been a double NAT for two years, and everything I have done so far has worked. There are specific things I have not done, like VPN, port forwarding, port triggering, etc. Getting a 401 error sounds like regular web browsing.
So, all sorts of web sites return 401 errors?
How are you going about connecting to the Orbi? (a PC connected with an Ethernet cable? The Orbi smartphone app?)
- jp104Feb 21, 2019Tutor
I can only connect via the App at this time. If I try to connect to the orbi login web page I get the 401 error. The 401 error occurs with almost every website that I try to access. The funny thing is that i set it all up 3 days ago and it worked fine until last night. Nothing has changed as far as I know but all of a sudden Im getting tons of 401 errors.
- FURRYe38Feb 21, 2019Guru - Experienced User
- jp104Feb 22, 2019Tutor
Just a follow up. I factory reset the orbi and during set up changed it to AP. Works like a charm now. Thank you for your help!
- FURRYe38Feb 22, 2019Guru - Experienced User
Great that its working.
For posterity, What is the Mfr and model# of the ISP modem the NG router is connected too? Just curious.
Enjoy the sytem. :smileywink:
