ravaoo
Oct 07, 2024Aspirant
HELP!!!!! I cant login anny more RBR50
I have a RBR50 end some RBS50's Recently i can't log in to my RBR50 on its IP asdress. In the orbi app i can't configure it to access mode. I need this because my internet provider has a HHCP and it...
- Oct 07, 2024
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.I recommend factory reset the RBR and setup from scratch with a wired PC/laptop and web browser first:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
You can do this with out the RBR being connected to the ISP modem if it has a built in router there already.
Then you can configure AP mode:
I recommend using MS-Edge or Firefox or Opera browsers for this.
Be sure to clear out all browser caches before going to 192.168.1.1 after the reset happens.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Or configure AP mode on the RBR.
Oct 07, 2024Guru - Experienced User
Couple of options,
ravaoo
This helped. It took me some houres to get connected, reset, etc.
my laptop stil cant connect, but....... my iphone can!!
I am in accesspoint modes now and i must manuly update my router. After that i could update the satelites online.
A verry big thank you for the quick response and for a solution!
- FURRYe38Oct 07, 2024Guru - Experienced User
Be sure you update any RBS first before the RBR is or bad things can happen.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
