u70115's avatar
u70115
Help in changing ethernet name and RBR50 wifi name.
My ethernet name is called "Fios-7SG9Y" and we name our wifi name from the RBR50 the same "Fios-7SG9Y".  I am experiencing a conflict with my computer which causes it to hang sometimes.  I have also ...
  • u70115's avatar
    u70115
    Jul 07, 2021
    Thank You for the answer to help be change ethernet name for my RBR50 wifi name.
    Everything seems to work correctly now (just before me making any changes to my ethernet name).  There was a update to Win 10 just before I was going to try the ethernet name change, and after the Win 10 update, everything seems to work correctly with no conflict.  I was testing everything after the update for a week, and I believe Microsoft Win 10 update may have resolved the issue!!!!!
    I do appreciate the process for me to change the ethernet name for my RBR50 WIFI as I will make sure the name don't conflict too!!!!
    I appreciate all the help you have shown me!!!!
    Thank You!!!
    Gary
