u70115
Jun 28, 2021Aspirant
Help in changing ethernet name and RBR50 wifi name.
My ethernet name is called "Fios-7SG9Y" and we name our wifi name from the RBR50 the same "Fios-7SG9Y". I am experiencing a conflict with my computer which causes it to hang sometimes. I have also ...
- Jul 07, 2021
Thank You for the answer to help be change ethernet name for my RBR50 wifi name.
Everything seems to work correctly now (just before me making any changes to my ethernet name). There was a update to Win 10 just before I was going to try the ethernet name change, and after the Win 10 update, everything seems to work correctly with no conflict. I was testing everything after the update for a week, and I believe Microsoft Win 10 update may have resolved the issue!!!!!
I do appreciate the process for me to change the ethernet name for my RBR50 WIFI as I will make sure the name don't conflict too!!!!
I appreciate all the help you have shown me!!!!
Thank You!!!
Gary
Jun 29, 2021Guru - Experienced User
For the Orbi system, log into the RBRs web page and under Basic tab/Wireless settings you can change the SSID name to anything you want. Set a new password here as well.
u70115
Jul 07, 2021Aspirant
Thank You!!!
Gary
- FURRYe38Jul 07, 2021Guru - Experienced User
:smileywink:
