RouterMan123
Jun 09, 2019Aspirant
Help! Inconsistent internet and basically unusable WiFi RBR50
Hello, In the morning today, my Orbi started acting up. I have an RBR50 as the router, with an RBS50 satellite. All throughout today, the internet has been extremely inconsistent. Speeds will var...
CrimpOn
Jun 10, 2019Guru - Experienced User
Are you able to connect the computer to the Orbi router with an ethernet cable? If so, lack of WiFi will not prevent using the Orbi web interface to see what is going on.
How is the Orbi connected to the internet? (i.e. what make/model of modem/router is it connect to?)
Is the Orbi in "router" or "AP" mode?
Typically, the Orbi assigns itself the IP address 192.168.1.1 and acts as the gateway to the internet for all devices connected to it. 10.0.0.1 is used when the Orbi is connected to another router which has already taken 192.168.1.1
- RouterMan123Jun 11, 2019AspirantYes, I am able to connect via an Ethernet cable, however the system works as follows: the orbi wires into a switch which distributed Ethernet connections to the house.
I don’t know the exact name, but it is an AT&T Modem, which directly links to the orbi internet in. The orbi is in Router mode and the AT&T router is not used besides a gateway to the orbi from the outside world.
Also, when the system is working okay-ish(as in normal until the issue gets fixed), the only way to access the Orbi router is via orbilogin.net. 10.0.0.1 will not work, and 192.168.1.1 will not work.
Another interesting issue besides the inconsistent internet speeds: Devices connected to the orbi via WiFi and Ethernet have a very hard time communicating with each-other. For example, my 3D printed is connected via WiFi, and to connect to it you simply enter Its local IP address in your browser. To improve this I port forwarded the printer globally, meaning I can access it anywhere with a global IP. The interesting part is after the issue with the orbi started I have been unable to connect to my printer via the local IP. Rather, I have to use the global port forwarded IP address to connect. The connection is also extremely slow and spotty. This is the same for any device at home, like printers and Alexa.- CrimpOnJun 11, 2019Guru - Experienced User
When you access the Orbi, how does the Advanced Home Page describe:
Router Information: IP Address
Internet Port: IP Address
IP Address: 172.16.0.1
There is no internet port reading anywhere on the home page. There is a LAN Port line, however to the right of it is blank. LAN Port is in bold.
- Steedvlx600Jun 11, 2019Luminary
Let me make sure I understand your setup first.
Is this your setup?:
ATT Modem/Router --> Orbi --> Switch --> All other ethernet devices
From your comments, I suspect the ATT modem is also a router (probably with 4 LAN ports). If this is the case, have you made sure that the ATT router's DHCP (and NAT) has been turned off ?
I ask, because this sounds like a system trying to run two DHCP servers on the same network. This would definitely cause the symptoms you describe.
Running the Orbi in AP mode will allow the ATT router to serve IP addresses to the entire network (including providing the Orbi with its IP addresses) Conversely, disabling DHCP on the ATT modem/router will allow the Orbi to operate in Router mode and perform DHCP functions for the rest of the network.
Does this seem like a reasonable place to start checking?- RouterMan123Jun 12, 2019Aspirant
This is my current setup:
|--->Switch ---> Any device with cable
ATT Modem/Router(**) --> Orbi --|
|--->Wifi devices attached
**Via ethernet cable, No other devices connected.
Yes, this sounds like a good plan. However, upon navigating to the DHCP page and even Wifi page on the ATT router, they simply won't load, meaning I can't view any of the settings or contents from these menus. However, on the home page of the ATT, it indicates its 2.4Ghz and 5Ghz Wifi's are active.
