RouterMan123
Jun 10, 2019Aspirant
Help! Inconsistent internet and basically unusable WiFi RBR50
Hello, In the morning today, my Orbi started acting up. I have an RBR50 as the router, with an RBS50 satellite. All throughout today, the internet has been extremely inconsistent. Speeds will var...
Steedvlx600
Jun 13, 2019Luminary
I am not familiar with that ATT Router. So, I cannot advise on how to access it. But, I still think you need to find a way in to disable the DHCP server. Or else connect your switch to the ATT router and use the Orbi in AP mode.
Good Hunting!
Steedvlx600
Also, the Wifi on the ATT router... That should probably go as well since you will be using the Orbi for Wifi
