3rdShore
Feb 23, 2019Aspirant
Help me refine my current Orbi home WiFi network (RBK50) (VS change to Nighthawk setup)
Greetings,
I believe this is likely a fairly common question here, but after searching for far too much time, I can't seem to come to the best conclusion for my case. I am looking for the absol...
Feb 24, 2019Guru - Experienced User
What is the distance from the test PC to the router and to the satellite?
Are you powering OFF the devices wifi radio for 5 seconds then back on for the mobile devices?
When speed testing the RBR, have ALL other wifi sevices disconnected from the base router, including the satellite to ensure your getting an accurate test.
Is Beamforming and MIMO enabled?
What is the status on Fast Roaming and Daisy Chain?
What is the building materials made up of in the basement area?
Any lead based painted walls?
Possible you might need a 2nd satellite in the basement area.
