voerman
Mar 18, 2020Aspirant
Help needed with ORBI issue
Router RBR50 with firmware version V2.5.1.8 and behind a modem in bridge modus Satelitte RBS50 with wired backhaul (cat7) and firmware V2.5.1.8 Satelitte RBS50 with wired backhaul (cat7) and firmw...
voerman
To what version should I downgrade?
Mar 18, 2020Guru - Experienced User
Try v30...
- voermanMar 23, 2020Aspirant
what is V30 ? I have V2.3.5.30 now ? Same result. Wifi cut outs.
- FURRYe38Mar 23, 2020Guru - Experienced User
Try a factory reset on the RBS and RBR. Walk thru the setup wizard and setup from scratch to see if this helps.
Yes, v30 is same as V2.3.5.30
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
If you turn OFF all RBS, does the RBR still have problems with WiFi?- voermanMar 23, 2020AspirantI have wired backhaul. So no wifi backhaul.
When I do a factory reset. To what version should I upgrade ? We know that v30 doesn’t work very well. Or is it different after a reset and upgrade to v30?
