NanoSuit
Jun 20, 2020Aspirant
Help Orbi Satellite Connection Type is 2.4ghz in my RBR20 and RBS20
for some reason my orbi keeps Connecting to 2.4ghz , so how do force it to stay on 5ghz ? my devices connect 5ghz but my satellite stays on 2.4ghz and it halves my connection speed. and thanks in a...
NanoSuit
concrete, but my huawei 5g cpe pro 2 can penetrate it and it is what i am connecting my orbi to.
Jun 20, 2020Guru - Experienced User
1. Concrete is literally the material (other than straight metal) that blocks wifi the best.
2. the huawei 5g cpe pro 2 is a wireless AX router. Not a AC device
3. the orbi uses the better connection. 5ghz doesn't passthrough materials as well as 2.4ghz. yes the 5ghz might passthrough but if the 2.4ghz is faster, its going to use that one
- NanoSuitJun 20, 2020Aspirant
is there anyway around it ?
like can i make it so the Satellites connect to 5ghz only ?
- CrimpOnJun 20, 2020Guru - Experienced User
NanoSuit wrote:is there anyway around it ?
The most obvious solution is a masonry drill bit to punch a hole through the wall in an inconspicuous place to use ethernet cable to connect the satellite to the router. There are telnet hacks to turn off individual Orbi radios, but my understanding is that the satellite 2.4G "fallback backhaul" uses the same radio as the front-facing 2.4G service. (but with a 'hidden' SSID)
The Huawei appears to be an awsome device. ($670USD) The feature list suggests expanding coverage by connecting Huawei WiFi access points, but does not mention any specific model numbers.https://consumer.huawei.com/en/routers/5g-cpe-pro-2/
I don't want to drill my wall or use hacks.
then i guess i am stuck with 2.4ghz until i find a better device for penetrating walls, does anyone have a suggestion for a device to replace my RBR20 and RBS20 ?
and thank you for all your replies, and for trying to fix my problem .
