NanoSuit
Jun 20, 2020Aspirant
Help Orbi Satellite Connection Type is 2.4ghz in my RBR20 and RBS20
for some reason my orbi keeps Connecting to 2.4ghz , so how do force it to stay on 5ghz ? my devices connect 5ghz but my satellite stays on 2.4ghz and it halves my connection speed. and thanks in a...
NanoSuit
is there anyway around it ?
like can i make it so the Satellites connect to 5ghz only ?
CrimpOn
Jun 20, 2020Guru - Experienced User
NanoSuit wrote:is there anyway around it ?
The most obvious solution is a masonry drill bit to punch a hole through the wall in an inconspicuous place to use ethernet cable to connect the satellite to the router. There are telnet hacks to turn off individual Orbi radios, but my understanding is that the satellite 2.4G "fallback backhaul" uses the same radio as the front-facing 2.4G service. (but with a 'hidden' SSID)
The Huawei appears to be an awsome device. ($670USD) The feature list suggests expanding coverage by connecting Huawei WiFi access points, but does not mention any specific model numbers.https://consumer.huawei.com/en/routers/5g-cpe-pro-2/
- NanoSuitJun 20, 2020Aspirant
I don't want to drill my wall or use hacks.
then i guess i am stuck with 2.4ghz until i find a better device for penetrating walls, does anyone have a suggestion for a device to replace my RBR20 and RBS20 ?
and thank you for all your replies, and for trying to fix my problem .
- CrimpOnJun 20, 2020Guru - Experienced User
Any idea how thick this concret wall is?
- NanoSuitJun 21, 2020Aspirant
I really i'm sorry for taking too long to reply,it is around 1 feet or 10 inches.
- plemansJun 21, 2020Guru - Experienced User
NanoSuit wrote:I don't want to drill my wall or use hacks.
You could try using powerline or a moca adapter to hardwire in the RBR to the RBS.
- NanoSuitJun 21, 2020AspirantI can't use the moca adapter because i don't have a cable, i will try the powerline then i will reply with the results.
