NanoSuit
Jun 20, 2020Aspirant
Help Orbi Satellite Connection Type is 2.4ghz in my RBR20 and RBS20
for some reason my orbi keeps Connecting to 2.4ghz , so how do force it to stay on 5ghz ? my devices connect 5ghz but my satellite stays on 2.4ghz and it halves my connection speed. and thanks in a...
Jun 21, 2020Guru - Experienced User
NanoSuit wrote:I don't want to drill my wall or use hacks.
then i guess i am stuck with 2.4ghz until i find a better device for penetrating walls, does anyone have a suggestion for a device to replace my RBR20 and RBS20 ?
and thank you for all your replies, and for trying to fix my problem .
You could try using powerline or a moca adapter to hardwire in the RBR to the RBS.
NanoSuit
Jun 21, 2020Aspirant
I can't use the moca adapter because i don't have a cable, i will try the powerline then i will reply with the results.
