st8king
Jun 25, 2018Aspirant
help phones not able to stay connected
I have been trying everything I can think of but I cannot get either of our household phones to get a reliable connection to our orbi wifi. All other clients in the house have 0 issues. We have Sam...
Jun 25, 2018Guru - Experienced User
What channels are you using? Auto? Try setting 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router.
Any other wifi neigbors near by? If so, how many?
Whats the Mfr and model# of the ISP modem?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- st8kingJun 25, 2018Aspirant
It is an Arris DG2470.
I have tried toggling all of your recommended settings that has not seemed to help unfortunately.
I will try your options setting up the modem to the orbi and see if that helps.
The strange part is the problem started when I tried to use chromecast audio. I had all kinds of problems connected while using it and it persisted for a few days and then seemed to fix itself after a week. About a month later I was using my chromecast audio again with my phone begun experiencing connectivity issues again and they have stayed around for the past few weeks so I am at a total loss.
Thanks,
Rich
- FURRYe38Jun 25, 2018Guru - Experienced User
There are known issues with CC devices. Something you should check into with Google. There devices have cause various issues with wifi routers.
I had read that online and I have since unplugged all of my CC devices however I am still getting the unstable connections on my phone. Did it somehow mess the routers up?
