st8king
Jun 25, 2018Aspirant
help phones not able to stay connected
I have been trying everything I can think of but I cannot get either of our household phones to get a reliable connection to our orbi wifi. All other clients in the house have 0 issues. We have Sam...
st8king
It is an Arris DG2470.
I have tried toggling all of your recommended settings that has not seemed to help unfortunately.
I will try your options setting up the modem to the orbi and see if that helps.
The strange part is the problem started when I tried to use chromecast audio. I had all kinds of problems connected while using it and it persisted for a few days and then seemed to fix itself after a week. About a month later I was using my chromecast audio again with my phone begun experiencing connectivity issues again and they have stayed around for the past few weeks so I am at a total loss.
Thanks,
Rich
Jun 25, 2018Guru - Experienced User
There are known issues with CC devices. Something you should check into with Google. There devices have cause various issues with wifi routers.
