Jeffmrhanlon
Dec 25, 2019Aspirant
Help, please Orbi rbk50
Hello, please help. My Internet connection works perfectly fine. I have a Arris surfboard modem SB 6141. When I set up the Orbi, no matter what I do, it won’t connect to the Internet. It p...
- Dec 26, 2019I found a solution- return and get google wifi
Jetdrive
Dec 25, 2019Luminary
You didn't say whether you restarted your modem. You need to do that before powering up the Orbi, otherwise it might not pick up an IP address. It would be still looking the mac address on your previous router.
- JeffmrhanlonDec 25, 2019AspirantThanks for the response. I have restarted the modem about 10 times at this point
- CrimpOnDec 25, 2019Guru - Experienced User
What are you using to set up the Orbi? (web interface on desktop/laptop? Orbi "app" on???)
Over ethernet connection or WiFi?
When the Orbi is powered up, not connected to the modem, a web browser will or will not connect to the Orbi WiFi (SSID) usiing the password on the label?
Sorry for the barrage of questions. This is a puzzle to unravel.
- JeffmrhanlonDec 25, 2019AspirantThanks for the reply. I truly appreciate it.
I have tried to set it up Using the mobile application, and on the computer.
However, I have not tried connecting it to a ethernet cable hooked up to computer yet- just via the wifi connection.
