Jeffmrhanlon
Dec 25, 2019Aspirant
Help, please Orbi rbk50
Hello, please help. My Internet connection works perfectly fine. I have a Arris surfboard modem SB 6141. When I set up the Orbi, no matter what I do, it won’t connect to the Internet. It p...
- Dec 26, 2019I found a solution- return and get google wifi
Jeffmrhanlon
Thanks for the response. I have restarted the modem about 10 times at this point
CrimpOn
Dec 25, 2019Guru - Experienced User
What are you using to set up the Orbi? (web interface on desktop/laptop? Orbi "app" on???)
Over ethernet connection or WiFi?
When the Orbi is powered up, not connected to the modem, a web browser will or will not connect to the Orbi WiFi (SSID) usiing the password on the label?
Sorry for the barrage of questions. This is a puzzle to unravel.
- JeffmrhanlonDec 25, 2019AspirantThanks for the reply. I truly appreciate it.
I have tried to set it up Using the mobile application, and on the computer.
However, I have not tried connecting it to a ethernet cable hooked up to computer yet- just via the wifi connection. - JeffmrhanlonDec 25, 2019AspirantUsing ethernet cable, the Wi-Fi box will hook up to my computer, but not based on Wi-Fi
- JeffmrhanlonDec 25, 2019AspirantAs an update, I manually updated the firmware, but it still won’t connect to the Internet.
- JeffmrhanlonDec 26, 2019AspirantI found a solution- return and get google wifi
