RavetheDave
May 03, 2021Aspirant
Help RBR50 and RBS50
I have had a major problem this week with my orbi setup to the point I have been looking at buying different ones! It started this week when my firestick kept dropping it signal from the satellite cau...
CrimpOn
May 03, 2021Guru - Experienced User
With all the devices except the phone connected with ethernet, that pretty much rules out any WiFi issues aside from the satellite to router backhaul link. Is the phone Speedtest running on the same satellite? And, does the phone Speedtest show 200mbs at the same time as the PlayStation is showing 1mbs?
RavetheDave
Hi
Yes the phone on WiFi will give 200 connected to the satellite but no the PS4 only give anything around 1-10 mb but if I put it in wifi it only gives around 15-20 mb! The ps5 is similar Ethernet and WiFi and the firestick just keeps freezing
- CrimpOnMay 03, 2021Guru - Experienced User
The factory reset kept the same Orbi firmware on satellite and router, correct? There has not been a change in firmware in the last week?
- RavetheDaveMay 03, 2021AspirantHi yes that is correct
Are the Firestick and PS's wired directly to the RBS50 satellite, or to a switch that is connected to the satellite?
