RavetheDave
May 03, 2021Aspirant
Help RBR50 and RBS50
I have had a major problem this week with my orbi setup to the point I have been looking at buying different ones! It started this week when my firestick kept dropping it signal from the satellite cau...
RavetheDave
Hi
Yes the phone on WiFi will give 200 connected to the satellite but no the PS4 only give anything around 1-10 mb but if I put it in wifi it only gives around 15-20 mb! The ps5 is similar Ethernet and WiFi and the firestick just keeps freezing
CrimpOn
May 03, 2021Guru - Experienced User
The factory reset kept the same Orbi firmware on satellite and router, correct? There has not been a change in firmware in the last week?
- RavetheDaveMay 03, 2021AspirantHi yes that is correct
- CrimpOnMay 03, 2021Guru - Experienced User
Are the Firestick and PS's wired directly to the RBS50 satellite, or to a switch that is connected to the satellite?
- RavetheDaveMay 03, 2021AspirantBoth are direct same as ps5 and sky q mini box
