Timweb
Oct 12, 2020Aspirant
Help!! RBR50 enable parental control and messed up HP Chromebook internet
I posted this early but i think it was in the wrong section, sorry. ButI have had this Orbi set up for about 2 years now with no problems with any device (up to 60 different devices). Last Thurdays i...
- Oct 14, 2020Thanks! I ended up reverting back to the firmware before the newest one that it updated too. The app now looks like it used too and is back to the circle. I rebooted the chrome book and now the internet works. I guess I just will leave it at it’s current firmware and not update it again!
Timweb
And no I wasn’t using armor or circle, I was just going into the device tab to turn off my son’s devices.
Oct 12, 2020Guru - Experienced User
V70 has some new parental controls.
I would factory reset the RBR and setup from scratch.
Be sure to clear out all browser caches as well.
- TimwebOct 12, 2020AspirantThank you! I think I’m going to manually upload the older firmware and see it that works before I do the factory rest as a last resort!
- FURRYe38Oct 13, 2020Guru - Experienced User
You should be resetting before or after you downgrade.
- TimwebOct 14, 2020AspirantThanks! I ended up reverting back to the firmware before the newest one that it updated too. The app now looks like it used too and is back to the circle. I rebooted the chrome book and now the internet works. I guess I just will leave it at it’s current firmware and not update it again!
