Timweb
Oct 12, 2020Aspirant
Help!! RBR50 enable parental control and messed up HP Chromebook internet
I posted this early but i think it was in the wrong section, sorry. ButI have had this Orbi set up for about 2 years now with no problems with any device (up to 60 different devices). Last Thurdays i...
- Oct 14, 2020Thanks! I ended up reverting back to the firmware before the newest one that it updated too. The app now looks like it used too and is back to the circle. I rebooted the chrome book and now the internet works. I guess I just will leave it at it’s current firmware and not update it again!
Oct 13, 2020Guru - Experienced User
You should be resetting before or after you downgrade.
Timweb
Oct 14, 2020Aspirant
