villeman
Feb 07, 2020Aspirant
Help requested RBR50 + RBS50 with switch
Hi, I am not very happy with my wifi performance and would like to connect ethernet cables to both my RBR50 and the satellite to see if this improves things. However, I cannot make this work and ...
CrimpOn
Feb 07, 2020Guru - Experienced User
What comes before the WAN cable? (a modem or a combination modem/router?)
Orbi will not be happy unless the router is connected using the yellow (WAN) port.
I sense that the ISP modem is located where the switch is and where all the existing ethernet cables meet at a patch panel, and that for some reason you do not want the router to be located there?
- villemanFeb 07, 2020AspirantHi,
Thanks. Before the WAN cable is a direct feed from my ISP fiber box. I have tested the ports from the switch and they work fine with the orbi in regular mode (router + satellite w wireless backhaul). - villemanFeb 07, 2020AspirantAlso, yes about the location. I do not want to have the router there as I want to use the ethernet ports on the router for my computer etc.
- FURRYe38Feb 07, 2020Guru - Experienced User
Regardless of router or AP mode, if you want the top ring LED to fully turn OFF or show correct indications when the RBR is in operation, you'll need to use the WAN port on the RBR. If you need additional LAN ports due to limited ports in back of the RBR, you can install a non manged non green ethernet Gb switch to add additional ports if you like. They may 5 ports all the way up to 52.
villeman- villemanFeb 07, 2020AspirantThanks. Understood about additional ports.
Do you mean that the following should work?
Switch port 1 -> RBR WAN port and Switch port 2 -> RBS port 1?
