villeman
Feb 07, 2020Aspirant
Help requested RBR50 + RBS50 with switch
Hi, I am not very happy with my wifi performance and would like to connect ethernet cables to both my RBR50 and the satellite to see if this improves things. However, I cannot make this work and ...
villeman
Also, yes about the location. I do not want to have the router there as I want to use the ethernet ports on the router for my computer etc.
Feb 07, 2020Guru - Experienced User
Regardless of router or AP mode, if you want the top ring LED to fully turn OFF or show correct indications when the RBR is in operation, you'll need to use the WAN port on the RBR. If you need additional LAN ports due to limited ports in back of the RBR, you can install a non manged non green ethernet Gb switch to add additional ports if you like. They may 5 ports all the way up to 52.
villeman
- villemanFeb 07, 2020AspirantThanks. Understood about additional ports.
Do you mean that the following should work?
Switch port 1 -> RBR WAN port and Switch port 2 -> RBS port 1?- CrimpOnFeb 07, 2020Guru - Experienced User
The solution depends (a lot) on the ISP device. Is it a "modem only" or a "modem/router".
In my view (opinion) the router and satellite should go where they provide the best coverage for the building. If the central hub is a bad location for a WiFi access point and the computer location is a better place, that makes sense, but needing more ethernet ports is not.
As there is only a single ethernet cable connecting the central hub to where the desktop computer (and other stuff) is located, a $25 unmanaged gigabit switch will connect everything back to the hub over that single cable.
- villemanFeb 07, 2020AspirantYou are absolutely correct. I will have a think about the location once again. My thinking was that the signal will be much more stable if both the router and satellite is connected with a cable
- FURRYe38Feb 07, 2020Guru - Experienced User
Yes. It works. How one of my Orbi systems is connected.
