jwhite518
Apr 13, 2020Tutor
Help understanding the current Orbi bundles - LAN ports required
I want to buy an Orbi but I'm not sure which bundle to get. My requirements are simple: 2 story house, 2000 sq feet, base router downstairs, satellite upstairs. The router I am replacing downstairs has 1 WAN/4 /LAN cables currently plugged in. The upstairs router needs one LAN port, but two would be better. Any advice is appreciated.
House size Find Your Orbi System:
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-SystemsIf you need extra ports and you get the lower edition 20 series Orbi, you can always add on additional LAN ports to the back of the RBR by installing a Gb LAN switch for more ports:
1 Reply
