lbuelow
Sep 07, 2020Follower
HELP wanlan conflict
I'm having a few problems with the set-up of my NetGear Orbi, and while there's lots of great suggestions here on the Community, I can't use any of them because I have the wanlan conflict issue that ...
CrimpOn
Sep 07, 2020Guru - Experienced User
Do you have a computer with an ethernet port?
- CrimpOnSep 07, 2020Guru - Experienced User
If you unplug the Orbi from the internet modem, a computer connected directly to the modem should be able to connect to the modem.
Also, an Orbi can be configured without being connected to the modem. Do a "Factory Reset", connect to one of the LAN ports with a computer and login to http://192.168.1.1. After you get it set up the way you want, then connect it to the modem.
