legendz97
Sep 08, 2022Aspirant
Help with 5Ghz
I need your help. I can't get 5Ghz working. Is it because of the signal? I dont understand much about it... but I can't connect to the 5ghz and neither does the satellite check the images belo...
KevinLiT
Sep 08, 2022NETGEAR Moderator
Hello legendz97,
Welcome to the NETGEAR Community!
I understand that you are having network connection issues with your 5GHz network band on your RBS40. Your RBS40 is able to successfully receive 2.4GHz network connectivity from the router. Your satellite could be just out of the 5GHz network band of the router.
Please follow the steps below to resolve this issue:
- First, ensure the router is broadcasting a 5GHz signal.
- Then, move the satellite closer to the router to establish a connection with the 5GHz network.
Best,
Kevin
Community Team
legendz97
Sep 09, 2022Aspirant
Hi,
Thanks for the reply,
These are my settings
- KevinLiTSep 09, 2022NETGEAR Moderator
Hello legendz97,
Thank you for providing that information!
The settings you currently have should not have an effect on your 5GHz network being able to reach your satellite. 5GHz is faster than 2.4GHz if it is in the recommended range of the device. Since 2.4GHz has a longer distance than 5GHz the satellite in your network configuration may be located in an area that is out of the 5GHz network range.
Best,
Kevin
Community Team
- legendz97Sep 09, 2022Aspirant
And if that happens, I won't be able to connect to my router through 5Ghz with my devices?
Hello legendz97,
If you are connected to your router and you are in the 5GHz range you will be able to connect to the 5GHz network. Since your satellite is out of that range then you won't be able to connect to the 5GHz range through any of the devices that are connected to the satellite.
Best,
Kevin
Community Team
Okay, that sounds completely fine. However, I think something is wrong with my router.
The router is 5m away from the satellite and it doesnt have 5ghz?
I'm 5 cm from the router with 4 different smartphones 5ghz capable and they don't get 5ghz connection?
I have instealled previous software to enable telnet, and when I tried to see "wla ssid" (the 5ghz connection name) it gave me a empty result
