Instarand
Jul 07, 2020Aspirant
Help with Optimum (Altice) Fiber and Router that cannot bridge
Hi Folks- My ISP (Optimum) recently upgraded my house to Fiber lines. The "Altice" modem/router combo cannot be bridged, according to Optimum tech support. The label underneath says "FiberGatew...
Instarand
Jul 12, 2020Aspirant
If I Try to use a switch, does The Altice and the Orbi Router have to be connected directly? I’d like to put the Orbi router in another location and wire it into the switch. Is that possible with also having 2 satellites hard wired into the switch?
CrimpOn
Jul 12, 2020Guru - Experienced User
If the satellites are connected to the router over WiFi, this would work fine.
When satellites are connected with ethernet, this does not meet the Orbi design. By design, the Orbi thinks that the WAN (yellow) port connects it to the internet and that satellites are connected to the LAN (white) jacks.
There is no harm in experimenting, but I would be prepared for disappointment.
- InstarandJul 12, 2020AspirantWhen optimum installed the new fiber connection, they obviously left the router where the lines enter the house. Which is in the basement on one far end of the house. So the Altice router and Orbi router are down there. It’s a less than ideal location for the router since I need to bounce WiFi to the satellites 2 or three times. But only the first satellite is actually receiving signal from the Orbi router, the other satellites are getting signal from another satellite. I’m speed testing at like 500 down and 500 up standing next to the Orbi router. But when upstairs at the far end of the house (2 floors up and opposite end of house) I am getting very slow connections (like 30 down 15 up). I assumed that if I hard wired the satellites, they’d be receiving router like connections at the other end of the house. Is this not the case? Ideas for alternative setup?
- CrimpOnJul 12, 2020Guru - Experienced User
Instarand wrote:
When optimum installed the new fiber connection, they obviously left the router where the lines enter the house. Which is in the basement on one far end of the house. So the Altice router and Orbi router are down there. It’s a less than ideal location for the router since I need to bounce WiFi to the satellites 2 or three times. But only the first satellite is actually receiving signal from the Orbi router, the other satellites are getting signal from another satellite. I’m speed testing at like 500 down and 500 up standing next to the Orbi router. But when upstairs at the far end of the house (2 floors up and opposite end of house) I am getting very slow connections (like 30 down 15 up). I assumed that if I hard wired the satellites, they’d be receiving router like connections at the other end of the house. Is this not the case? Ideas for alternative setup?Yes, this is a typical practice for installers. Really unfortunate. And, the reason I purchased my Orbi system.
This is a good time to ask about the ethernet wiring.
- Is it already in place, with cable running from that point in the basement to various locations around the building where you would like to place the Orbi units (and other devices)?
If this is the case, then the "correct" practice would be to install one new ethernet cable from the hub to the Orbi router location.
(i.e. one cable to the WAN port and one cable back from a LAN port to the switch.) - Or, is the intention to install ethernet wire from a central point to all these locations?
If this is the case, then one ethernet can go from the Altice router to the Orbi in the new location, which is connected to the switch in the new location, which then feeds the Orbi satellites (and other devices).
- InstarandJul 12, 2020AspirantMy house is already wired with cat5e Ethernet outlets - and fortunately they all lead to where the Altice router is now (where fiber lines enter). They were previously used for phone lines which are no longer needed.
If possible, I’d really love to get the router to one of the hard wire locations instead of in the basement - if that’s possible to do via switch or by connecting that cat5e line direct to the Altice. My thought was hard wire the Orbi router somewhere central in the house - obviously leave the Altice router in the basement with the fiber line. And then hard wire satellites at various locations throughout the house.
Should everything go into the switch? Or should I hook the Orbi cable directly into the Altice router and then route the satellites through a switch?
Or is it better to leave the Orbi in the basement directly connected to the Altice router, and then connect the hard wired satellites directly into the Orbi ports and leave the switch out of the equation all together? - CrimpOnJul 12, 2020Guru - Experienced User
The Altice must connect to the optical fiber (the green "PON" port at the bottom), so it must remain in the basement.
Unless there is a lot of WiFi usage in the basement, it would be much better to move the Orbi router upstairs where it can be connected to the Altair with ethernet. (It can ONLY connect to the Altair with ethernet.)
At that point, you have more choices. The WiFi backhaul connection between the Orbi router and satellites may be "good enough" and essentially "you're done." If the router can be centrally located, maybe the satellites can be placed close enough to get a good signal and still cover the remaining living space.
You will know very quickly if the Cat5e cable was properly installed and terminated when you hook up the router. On the Advanced Tab, click on the blue box "Show Statistics". If the WAN link shows as 1000M/Full, then the router is connected to the Altair at full speed.
- InstarandJul 12, 2020AspirantI realize this is a ridiculous drawing. But if I were to connect satellites hard wire, which option is best?
1) no switch, satellites hard wired to Orbi directly, then Orbi to Altice directly.
2) satellites into switch. Switch to Orbi. Orbi to Altice.
3) everything to switch. - InstarandJul 12, 2020AspirantThe reason for the above question is because there really is no central location in my house that is hard wired for the Orbi router to go. So regardless of what I do, I’d really like to hard wire satellites if that’ll get stronger signal from those satellites.
These are great drawings.
#1 "works" as long as this layout provides adequate coverage of the areas that need coverage.
- Requires no additional equipment.
- Requires no additional ethernet wire.
- Can be tested immediately.
- May not be a great use of the Orbi WiFi in the basement if there are no WiFi devices in the basement.
- Additonal devices can be wired to the two upstairs satellites.
- One Orbi LAN port remains which can be used to connect one additional upstairs device to the Orbi if ethernet wire goes to the location where the device is placed.
#2 also "works"
- Provides three WiFi units upstairs for greater upstairs coverage.
- Provides less coverage in the downstairs, where there may be no need for.
- Provides three Orbi units that upstairs devices can be wired to.
- Provides additional ethernet ports that other upstairs devices can be wired to if there is ethernet wiring to the location where those devices are placed.
- Requires addition of an inexpensive, unmanaged gigabit switch (under $40).
- BUT, requires a new ethernet installation back to the Altice location.
#3 does not work as shown. The Altice should be connected directly to the Orbi and the Orbi connected to the new switch.
- Allows more upstairs devices to be "wired" to the downstairs Orbi, even if they are not in the same room with the Orbi satellites.
- But, the downstairs Orbi WiFi may be "wasted" and upstairs coverage may suffer.
- Requires addition of an inexpensive, unmanaged gigabit switch. (under $40)
I suggest you start with option #1 and check out the upstairs WiFi coverage. If it is what you need, then you are done.
If upstairs coverage is NOT adequate, then #3 will not be any better, so installing another ethernet cable to the Orbi location is the next step.
- InstarandJul 12, 2020AspirantThank you for your continued comments and input. Do you accept gratuity??? :)
Question: in option number 2, why would I need an additional line installed? Am I able to connect the Orbi router into an existing Ethernet port in my house? I’d then go and find that line in the basement and connect direct into the Altice... - CrimpOnJul 12, 2020Guru - Experienced User
That is because #2 shows TWO lines between the Orbi and the basement. (one to the Altice and one to the swwitch = two).
- InstarandJul 12, 2020AspirantOh right, duh!
Ok, second to last question. In option number 2, Which port am I using on the Orbi to the Altice and which am I using From the Orbi to the switch?
Final question (maybe!). Most of my pre-installed Ethernet cables are labeled CAT5E. However, some are labeled as you see in the attached photo. I assume these cables are NOT cat5e and will not carry gigabit speeds, correct? - CrimpOnJul 12, 2020Guru - Experienced User
WAN (yellow) port on Orbi goes to Altice. any LAN (white) port goes to switch.
The photo did not appear to be attached, sorry.
Try again?
- InstarandJul 12, 2020AspirantDid it work this time?
- InstarandJul 18, 2020AspirantIf you hard wire the satellite, would you be getting better WiFi performance output From that satellite versus a wireless connection to the router? Or would a satellite with wireless connection to the router offer identical performance versus a wired satellite? It seems that hard wiring a satellite should offer a stronger connection and therefore a stronger WiFi output...?
