Instarand
Jul 07, 2020Aspirant
Help with Optimum (Altice) Fiber and Router that cannot bridge
Hi Folks- My ISP (Optimum) recently upgraded my house to Fiber lines. The "Altice" modem/router combo cannot be bridged, according to Optimum tech support. The label underneath says "FiberGatew...
CrimpOn
Jul 07, 2020Guru - Experienced User
If this is your unit, page 44 says that pressing the WPS button for 5 seconds will turn the WiFi ratios on or off.
https://fccid.io/2ACJF-FGW-GR240BG/User-Manual/Users-manual-3621380
kimballct
Aug 15, 2020Aspirant
If you have wireless altice mini box’s do not turn off the Wi-Fi on fiber gateway. This will disconnect the box’s and you will not have tv service.
- InstarandAug 16, 2020AspirantAs soon as I saw those Altice mini boxes I had a contest with my friend on who could throw them further into the ocean. LOL. Junk!!!
I’ve got the Altice router wired into the Orbi which is set in AP mode. Two satellites connected and everything is good for now.- Pequot20Aug 18, 2020AspirantDid you have to reset the Orbi to factory?
I cannot access it at all unless I hook it up to the old modem which I have not disconnected yet.- InstarandAug 18, 2020AspirantI have fiber lines. So there’s no longer a stand alone modem. Optimum gives me a router/modem combo which can not be replaced. So I leave that in place and connect the Orbi and put it in AP mode and connect everything to that. No I didn’t have to factory reset. Just need to go into admin tools and set to AP mode.
