EitanCaspi
Mar 02, 2018Aspirant
Help with Orbi Model selection
Hello, I am looking into buying Orbi but I wish to buy the right model that will best cover my home size and structure. I tried to find a kind of product selector, but wasn't able. How can I select ...
- Mar 02, 2018
Yes you could get the RBK50 and add more Satellites later I believe.
nicholb
Mar 02, 2018Luminary
Go here and scroll down to "Find Your Orbi". There is tool where you can enter your details and it will recomend a system size.
- EitanCaspiMar 02, 2018Aspirant
Thank you Nichol!
Also, I now found this great support table comparing the Orbi models, for anyone looking for a matching model:
Which Orbi WiFi System is best for me?
kb.netgear.com/000038220/Which-Orbi-WiFi-System-is-best-for-me
