EitanCaspi
Mar 02, 2018Aspirant
Help with Orbi Model selection
Hello, I am looking into buying Orbi but I wish to buy the right model that will best cover my home size and structure. I tried to find a kind of product selector, but wasn't able. How can I select ...
- Mar 02, 2018
Yes you could get the RBK50 and add more Satellites later I believe.
EitanCaspi
Thank you all for the detailed replies!
One last question - Say I buy the RBK50 and eventually I have the need for more coverage - does Netgear have a sat I can buy one peice of and add to the existing RBK50 installation?
Mar 02, 2018Guru - Experienced User
