JoshBear
Oct 05, 2019Aspirant
Help with Orbi RBK50 and video connection
Hi All, I have an orbi system with multiple satelites and it was working well. A week and a half ago it sudenly started to disconnect most devices after lots of rebototing the router and the or...
ekhalil
Oct 05, 2019Master
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
- If you see two private IP addresses listed in the first two hops then you have double NAT, and this can be the reason for the issue you’re reporting
- If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the cause of the issue,
JoshBear
Hi
thanks for the help. I opened terminal on a mac and did what you said but have no idea how to interpret the results
I got lots of rows of numbers and text and some of them had row numbers 1 to 9.
row 1 had an IP address
row 2 just had * * *
row 3 just had * * *
row 4 had numbers again.
thanks
Josh
- ekhalilOct 05, 2019MasterI’m interested to know if the IP addresses in row 1 and 2 are private or public IP addresses.
Private IP addresses starts with 10.x or 172.16.x up to 172.31.x or 192.168.x
https://en.m.wikipedia.org/wiki/Private_network
