marty1959
Jan 23, 2020Aspirant
Help with Orbi RBR20 Connection to Spectrum Modem
I just switched from google fiber to spectrum (use to be Time Warner Cable). My orbi mesh worked fine with Google fiber. I cannot get an internet connection with the new spectrum modem. When I follow...
CrimpOn
Jan 23, 2020Guru - Experienced User
marty1959 wrote:
Also, the brand on the Spectrum modem is not listed. But a model number is E31T2V1
This is the Hitron model that I have from Spectrum. My RBR50 is plugged directly into the E31TV1. This is a "modem only" (with telephone line capability, which I use). So, the Orbi must be configured as a router (the default). If the Orbi is in access point (AP) mode, then the Orbi will get an IP address, but it will not create IP addresses for any device attached to it, so nothing will be able to access the internet. The satellites will not connect because they will never get an IP address. (Now that I think about it, maybe every DHCP request will pass through the Orbi and the modem will get confused by all of the different MAC addresses and simply "give up".)
marty1959
Thank you. So what do you suggest? If it's acting as an access point, should I reset the router to factory settings? the sattelites appear to be working too. All this is currently working with the Belkin router bridging the two devices (Spectrum modem connected to Belkin, connected to the ORBI), but it certainly doesn't seem right. When I accessed the ORBI app on my phone, attempting to be administrator (username: admin), the default password (password) is not being accepted. So this make me think I should "reset" the ORBI? I appreciate people's thoughts. Thank you.
- CrimpOnJan 23, 2020Guru - Experienced User
Since you cannot access the Orbi web interface (not knowing the admin password), the only step left is a "factory reset". This will put it back into router mode and reset the admin password to "password" (which the setup will want you to change).
Connect directly from the Orbi yellow (WAN) port to the modem.
Good Luck!
- marty1959Jan 23, 2020Aspirant
Thank you. I am at work and will try this tonight. Appreciate your suggestions. :)
