marty1959
Jan 23, 2020Aspirant
Help with Orbi RBR20 Connection to Spectrum Modem
I just switched from google fiber to spectrum (use to be Time Warner Cable). My orbi mesh worked fine with Google fiber. I cannot get an internet connection with the new spectrum modem. When I follow...
CrimpOn
Jan 23, 2020Guru - Experienced User
Since you cannot access the Orbi web interface (not knowing the admin password), the only step left is a "factory reset". This will put it back into router mode and reset the admin password to "password" (which the setup will want you to change).
Connect directly from the Orbi yellow (WAN) port to the modem.
Good Luck!
marty1959
Thank you. I am at work and will try this tonight. Appreciate your suggestions. :)
