snoosnaa
Dec 31, 2017Aspirant
Help with port forwarding
Hello,
I am trying to host a server for a PC game for my friends and myself. The game is ARK: Survival Evolved specifically. My Orbi is connected to an Arris tg1682 modem from Specrum. I have no trouble setting up the port forwarding through the Orbi router, but it seems that the modem also may need to have the ports forwarded? When I do port checking, the port always comes up as not open, even when using the Orbi router IP of 192.168.1.1. The modem from Spectrum is located at 192.168.0.1 and I have set the port forwarding for both.
- You really should only have one device functioning as a router in your network. That means either putting the TG1682 into bridge mode or enabling AP mode on the Orbi. Then set up port forwarding on the lone router.
- snoosnaaAspirantThank you for the fast response. My Orbi satellite is currently in my room in order to supply the wired connection. Due to logistics with my housemates, we cant get a good location for either the Orbi or cable modem to supply a network to the whole house wirelessly while still supplying a wired connection in my room. So I have a separate network I believe, but it is running through the cable modem(Arris). I don't know how to set up the other modes you mentioned properly, but I am willing to do what I need to.
Does upnp have anything to do with it?
Thanks again.- snoosnaaAspirant
OK so it looks like AP mode is what I want. Once I set that, I would just use the same WIFI that my friends already use, and still plug in through the satellite in my room for a wired connection.
In this case, where would I do the port forwarding, from the cable modem?
And sorry for the repeat, but does upnp have anything to do with it?
