alirazajivraj
Apr 18, 2019Aspirant
Help with Virtual server (lorex camera)
Hoping someone can help me out with this issue. Recently got an Orbi wifi mesh system. Everything works perfectly except for lorex Camera system. I cannot access the camera using my iphone. I know th...
CrimpOn
Apr 18, 2019Guru - Experienced User
Have you looked into "port forwarding"? On the Advanced Tab, Advanced Setup, Port Forwarding.
There have been questions about Lorex camera systems before. Here's one: https://community.netgear.com/t5/Orbi/Orbi-with-Lorex-netHD/m-p/1146288#M391
I did not realize that a Lorex installer program could make changes to a router configuration. My guess is that this is a common problem for Lorex users and Lorex support would have information on how to set it up.
alirazajivraj
I did try to port forward but i keep getting an error message " This IP address should be in the same subnet as the LAN IP address."
- CrimpOnApr 18, 2019Guru - Experienced User
Oh, geez. Sorry. I have never set up port forwarding. My camera system uses a central server to maintain links to the cameras, so I do not have to have a dynamic DNS account or set up port forwarding.
May be time to read up, or ask a specific question on this forum that will draw the attention of experts.
- SW_Apr 18, 2019Prodigy
alirazajivraj wrote:
... an error message "This IP address should be in the same subnet as the LAN IP address."
You can try this out and see if it helps:
If you can't access Lorex admin page, plug the old router back in and login to Lorex admin page. Check its TCP/IP address to see if it's on a different private network (subnet) than the router. If yes, click DHCP box, save and turn it off. Now replace the old router with Orbi. Plug everything back and power up, the Lorex should now get a new IP address from Orbi, which will be in same subnet as Orbi.
