alirazajivraj
Apr 18, 2019Aspirant
Help with Virtual server (lorex camera)
Hoping someone can help me out with this issue. Recently got an Orbi wifi mesh system. Everything works perfectly except for lorex Camera system. I cannot access the camera using my iphone. I know th...
alirazajivraj
I did try to port forward but i keep getting an error message " This IP address should be in the same subnet as the LAN IP address."
SW_
Apr 18, 2019Prodigy
alirazajivraj wrote:
... an error message "This IP address should be in the same subnet as the LAN IP address."
You can try this out and see if it helps:
If you can't access Lorex admin page, plug the old router back in and login to Lorex admin page. Check its TCP/IP address to see if it's on a different private network (subnet) than the router. If yes, click DHCP box, save and turn it off. Now replace the old router with Orbi. Plug everything back and power up, the Lorex should now get a new IP address from Orbi, which will be in same subnet as Orbi.
