Brownb01
Apr 23, 2019Aspirant
Help with WiFi setup
Hello. I was wondering if I could get some help. Current setup - Internet provided by AT&T through a Netgear Nighthawk MR1100 with a Netgear 3200 in AP mode. I have the WiFi disabled on the MR110...
CrimpOn
Apr 24, 2019Guru - Experienced User
Brownb01 wrote:
I need to expand my WiFi coverage and run more devices - mostly nest cams. This is a vacation place, with 8 or so cams, lots of automation and many guests on the weekends. What will be the best way to expand the WiFi coverage and stay on a single SSID?
FURRYe38 is correct. Single SSID coverage depends on the building size and materials. It's amazing how it is possible to get internet access almost anywhere at a reasonable cost. Is 20 devices going to be enough when 8 are taken up with cameras and more with automation before the "many guests" arrive on the weekends?
