Tony_McDonell
Sep 21, 2021Aspirant
HI, I have an ORBI RBR850 it doesn't seen to be assigning IP addresses to wired devices.
My RBR850 is not allowing wired devices on my network to be assigned IP addresses.
My router is configured with 15 mac addresses that get static IP addresses, most of these are wired, TV, Amp, DVD etc, they are all connected to a netgear switch, which connects to a CISCO SG100-16 switch which connects to the ORBI, IP range is from 192.168.2.4 to 192.168.2.99 for these devices. I have tried to connect just the TV directly to the ORBI but still no luck with an IP assignment. I have also taken the TV off DHCP and assigned a static IP (Same as what the router should have assigned) but still no access to the internet. When I connect the the TV to the wireless network it connects but i doesn't get the reserved address, 2.9. Interestingly my laptop does get its reserved address.......2.30? but I can't ping it from another PC, actuall I can't ping anything within the address reservation table?
DHCP range is 192.168.2.100 to 192.168.2.200
Rebooting the router doesn't help.
I have no idea what is going on here, I haven't done a factory reset but its next on the list. I thought I post here first before starting from scratch.
Has anyone ever experienced anything like this before?
I should add this all happened suddenly, It was working when I went to bed, woke up in the AM and it wasn't :)
- Tony_McDonellAspirant
RBR850 Firmware Version
V3.2.18.1_1.4.14 - CrimpOnGuru - Experienced User
Does the TV have different MAC addresses for the ethernet and WiFi interfaces? Orbi IP assignment is strictly by MAC address, so if they are different..... they are different!
An interesting choice for the Orbi IP subnet to be 192.168.2.x, rather than the more typical 192.168.1.x Is the Orbi (gateway) 192.168.2.1?
Hi, and thanks for the reply.
Yes your right, the MAC address on the TV is differernt for the wired v wireless. That answers that question.
I used 2. for the network here at our farm as we have another place in Sydney that uses 1. I didnt want any IP confilcts if I ever put a VPN between the 2 places.
Yes the ORBI uses 2.1, I have another 2 routers set up as wireless gateways, one in my shed and the other in the old shearing shed, only the ORBI is configured at a DHCP server. The other routers use 2.2 and 2.3.
On the older residential Orbi, I would use the debug option to capture the LAN/WAN traffic.
i.e. http://orbilogin.net/debug.htm
After it starts capturing, I would power up a bunch of devices so that they go through the DHCP process.
Then, save the file to my PC and open the file lan.pcap (inside the zip file) with Wireshark.
Set a display filter of dhcp on Wireshark and it should show all of the devices going through the DHCP process.
i.e. request, offer, etc. https://en.wikipedia.org/wiki/Dynamic_Host_Configuration_Protocol
If the DHCP traffic does not get captured at the Orbi LAN interface, "The game's afoot."
Either the Netgear or Cisco switch is blocking DHCP. Maybe there is a VLAN set up by accident?
I keep a 50ft ethernet cable on hand so that I can connect devices directly to the LAN port on the Orbi router.
(a 100ft cable is about $20US, but my house is so small I have never needed one that long.)
The DHCP offer should show:
- The IP address offered
- Subnet mask of 255.255.255.0
- Gateway address of 192.168.2.1
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
