Hermod69
Aug 03, 2021Aspirant
Hi ping with Nokia G-010G-Q fiber modem and Netgear ORBI RSR50
Hi. I have internet from Telenor here in Norway. Currently fiber connection with a Nokia G-010-G-Q fiber modem delivering 360Mbps up and down. I have 1 RBR50 and onr RBS50. All devices have firmw...
Aug 03, 2021Guru - Experienced User
Whats the CAT version of cables being used? CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Is the cable TV decoder unit wireless or wire connected to the Orbi system? Wired would be preferred.
- Hermod69Aug 08, 2021Aspirant
Hi,
I have not done a factory reset yet after last firmware update.
I use CAT 8 in my house.
The house is abaout 180 square feet divede in 2 floors.
The sattelite, RBS, is connected to RBR with cable. There is a switch between the devices.
The TV-Decoder is connected with cable. No option for Wifi yet.
- FURRYe38Aug 08, 2021Guru - Experienced User
What is the distance between the router and 📡?
What is the Mfr and model# of the ethernet switch in the configuration?
