peteytesting
Oct 05, 2016Hero
hidden features
hi guys just incase you havnt found it yet there is a hidden page to access https://192.168.1.1/debug.htm one feature you will find there is an advanced attached device list that wi...
ronhanson01
Oct 08, 2016Aspirant
There are a number of hidden things. you can find them using teleport pro http://www.dslreports.com/faq/11955
interesting is: /GuestManage_sub.htm
TheJedi
Nov 06, 2016Aspirant
The link is dead, can you re-post? I'm coming from ASUS routers and it's been extremely tough getting used to this very limited very basic user interface. The features I'm looking for the most are the ability to see which device is using up my bandwidth and also what the signal strength is of every device. If anyone finds this please post.
- peteytestingNov 06, 2016Hero
TheJedi wrote:The link is dead, can you re-post? I'm coming from ASUS routers and it's been extremely tough getting used to this very limited very basic user interface. The features I'm looking for the most are the ability to see which device is using up my bandwidth and also what the signal strength is of every device. If anyone finds this please post.
to have that level of monitoring you are best to use your asus as a router and the orbi in AP mode and get the best of both worlds
