peteytesting
Oct 05, 2016Hero
hidden features
hi guys just incase you havnt found it yet there is a hidden page to access https://192.168.1.1/debug.htm one feature you will find there is an advanced attached device list that wi...
st_shaw
Jan 16, 2017Master
The "hidden feature" is the ability to see more detail about the connected devices, e.g. wired versus wireless, and connected band. As detailed in an earier post on this board, this feature can be enabled by changing a variable on the router. Do so at your own risk!
- Go to the debug page and enable telnet
- Telnet into the router
- Execute the following:
nvram set enable_adv_attached=1
nvram commit
- Exit telnet
- Go to the debug page and disable telnet (please don't forget this step!)
AndUrbi
Jan 16, 2017Guide
Yeah, the enable_adv_attached variant is somewhere between "way way better" and "infinitely better". Dunno why that isn't the default, but at least the functionality is still there!
- st_shawJan 16, 2017Master
I agree! It's very useful to see the additional details. A lot is still missing though.
I run another brand of access points at another site and they provide complete information for each client: mode, TX rate, RX rate, channel, RF band, signal strength, uptime. It's frustrating how little information is available on the consumer stuff.
- peteytestingJan 16, 2017Hero
st_shaw wrote:I agree! It's very useful to see the additional details. A lot is still missing though.
but that is the point , the orbi is a coustomer level device that for the most point ppl want to plug and play and dont care about whats under the hood , make it too complex and you start to lose the concept it was initially designed around , i still see ppl wanting ethernet backhaul which to me makes no sense to buy the orbi if you already have structured cabling in place
pete
I agree on the wired backhaul. I think access points are a better solution to extend WiFi coverage if you have the wires. The reason I have the Orbi here is because I have no easy way to wire the house, plus I have a large property that can use longer reach outside.
I understand your point about keeping things simple. However, I believe Netgear could include more details on attached clients without making the devices any more complex to use. It's just information, not a setting to fiddle with.
- AndUrbiJun 03, 2017Guide
AndUrbi wrote:Yeah, the enable_adv_attached variant is somewhere between "way way better" and "infinitely better". Dunno why that isn't the default, but at least the functionality is still there!
So it turns out that changing the Orbi from router made to AP mode resets this option. No big deal, do the telnet dance and turn it back on. HOWEVER... it doesn't actually do anything in AP mode. My "attached devices" page still groups all client devices at the bottom no matter whether they're on the main Orbi or on a satellite.
Fail, fail, fail.
- peteytestingJun 03, 2017Hero
yes it has changed and i assume will change again before its finished , however its easy enough to see whats connect to sats by accessing their web pages
