stevefxp
May 01, 2019Apprentice
Hidden Network?
Hello all,
I have an Orbi router(RBR50), one RBS50 satellite, and one RBW30 satellite. I see the radios for the 2.4 and 5 GHZ ranges but I am also seeing a hidden network in each range. It looks to...
stevefxp
I see the wireless backhaul hidden networks, as they are up high in the 5 GHZ range. The one I am talking about sit right on top of my actual SSID, so it seems that these hidden networks, one in the 2.4GHZ and one in the 5 GHZ must be for something else. Take a look at the attached file. You will see the backhaul network up high in the 5 GHZ zone.
May 01, 2019Guru - Experienced User
Hard to tell with all that going on in that picture. So if you turn off the RBR this one disappears?
What FW version are you currently running?
- stevefxpMay 01, 2019Apprentice
Running 2.3.1.48 and 2.3.0.4...
I have also enabled a guest network and now this guest network is showing two devices that do not have a WPA2 password, which I thought could not happen since this is a mesh network.
- FURRYe38May 01, 2019Guru - Experienced User
Now if you disable the Guest Network, do those disappear fully?
