stevefxp
May 01, 2019Apprentice
Hidden Network?
Hello all,
I have an Orbi router(RBR50), one RBS50 satellite, and one RBW30 satellite. I see the radios for the 2.4 and 5 GHZ ranges but I am also seeing a hidden network in each range. It looks to...
May 01, 2019Guru - Experienced User
Hard to tell with all that going on in that picture. So if you turn off the RBR this one disappears?
What FW version are you currently running?
stevefxp
Running 2.3.1.48 and 2.3.0.4...
I have also enabled a guest network and now this guest network is showing two devices that do not have a WPA2 password, which I thought could not happen since this is a mesh network.
- FURRYe38May 01, 2019Guru - Experienced User
Now if you disable the Guest Network, do those disappear fully?
