stevefxp
May 01, 2019Apprentice
Hidden Network?
Hello all,
I have an Orbi router(RBR50), one RBS50 satellite, and one RBW30 satellite. I see the radios for the 2.4 and 5 GHZ ranges but I am also seeing a hidden network in each range. It looks to...
stevefxp
Running 2.3.1.48 and 2.3.0.4...
I have also enabled a guest network and now this guest network is showing two devices that do not have a WPA2 password, which I thought could not happen since this is a mesh network.
May 01, 2019Guru - Experienced User
Now if you disable the Guest Network, do those disappear fully?
