Breggen
Jun 27, 2018Star
Hidden Orbi QOS settings. Do they work?
Once you are logged into your Orbi router webpage, http://orbilogin.net, the UI on the web pages does not seem to include any options for QOS settings. There is a link For "QOS Setup" If you click o...
Jun 27, 2018Guru - Experienced User
Probably just a place holder or a common template used for all NG routers. I see Setup QoS rules takes you to the speedtest app and not the more advanced QoS settings to input values. Something NG may or maynot bring to the Orbi. Will be up to them. Users have asked about more advanced QOS features. Up to NG though.
