Breggen
Jun 27, 2018Star
Hidden Orbi QOS settings. Do they work?
Once you are logged into your Orbi router webpage, http://orbilogin.net, the UI on the web pages does not seem to include any options for QOS settings. There is a link For "QOS Setup" If you click o...
st_shaw
Jun 27, 2018Master
You should assume that the hidden pages do not work.
If you go to the non-hidden Orbi QoS page (at http://192.168.1.1/adv_index.htm) and click on the ? help icon at the bottom you can read a description of NETGEAR's Dynamic QoS function that is supported by the router
Dynamic QoS Help
Dynamic QoS improves online gaming and online streaming quality by prioritizing Internet bandwidth usage. When the router detects online gaming and online streaming traffic, the router tries to limit background traffic such as BitTorrent or FTP downloads to improve gaming and streaming.
Internet Bandwidth - Let Speedtest detect my Internet bandwidth (recommended): Accurate Internet bandwidth is required for Dynamic QoS to work properly. The router automatically runs Speedtest the first time you enable Dynamic QoS. Click the Speedtest button to recheck your bandwidth. Avoid any Internet activity while Speedtest is running.
Several NETGEAR routers have "Dynamic QoS" which requires no settings from the user. A speedtest is run, then the results are used to set the upload and download limits that one would normally enter into a manual QoS menu. This is why there are no settings for you. None are required.
I have no idea whether Orbi's Dynamic QoS works. I use Orbi in AP mode, so I've never tried it. You can try it for yourself, but you'd need to reset the router to do a baseline test with no QoS, as there's no way to turn the feature off.
- BreggenJun 27, 2018Star
I had called customer service about this question yesterday and I just got a response after they apparently "contacted their level two technical team".
They said that the hidden QOS settings do in fact work but that Netgear plans to delete those hidden pages form the Orbi UI in the future. They were unsure if the QOS settings that I changed would contiue to take effect after Netgear deletes those pages.
I honestly do not have a lot of fatih in those answers. Until I hear from one of the technicians who actuallys works on the Orbi or Netgear releases an offical statement I won't know what to think about this issue.
Also, as far as "Dynamic QOS" on the Orbi if you type in this adress once you are logged into your Orbi router, http://orbilogin.net//QOS_dynamic.htm, you can get to another apparently hidden page that apparently has setting options for Dynamic QOS. It seems that the Dynamic QOS is turned off by default on the Orbi if you belive what you see on that page.
As I understood from what I have read elsewhere the Orbi Uses WMM for prioritizing traffic by default and that is the only type of QOS manamagement that is turned on by default for the Orbi routers. I had never read anywhere that the Orbi uses Dynamic QOS.
Do the Orbi routers use WMM or Dynamic QOS by default? Is there some offical documentation somewhere from Netgear that you can point to?- FURRYe38Jun 27, 2018Guru - Experienced User
WMM differs from QoS. WMM is QoS for wireless devices only.
I wouldn't be bothered by QoS, use it for what it is and don't read into it. It is was it is and for the Orbi system, it's meant to be simple as the Orbi is meant for simplistic use and users. If you want or need more advanced QOS features, then the Orbi may not be for you. You can always get you a router that has the QoS features you need and use the Orbi system in AP mode.
I understand that "You can always get a router that has the QoS features you need and use the Orbi system in AP mode. " but it is disappointing that the Orbi does not have easily configurable QoSs settings. It is an expensive router.
The Orbi is the most powerful mesh router that is made. The Linksys Velop is probably in second place in terms of range for a triband mesh system. I wanted the most powerful mesh router system so I got the Orbi.
Also, the Orbi has has more LAN ports on the router and the satellites than the Velop system does, and the Orbi has a USB port.
However the Velop has a much better app and a better browser management page. They have better UI's and more features, like QoS settings.
With the Velop app you can easily prioritize devices and in the browser management you can set a variety of QoS priorities.
The Velop app also tells you which satellite or router that each device is connected to and which band it is connected on (2.4 or 5). The Velop app has many other "advanced features" that can be set in the app. The Orbi app is close to useless.
QoS settings are an industry standard for most mid level routers in 2018. Orbi is a 370-1000+ dollar mesh system. For those prices it should include the features that are industry standard for even mid priced routers. Also, there is no reason that the Orbi app needs to suck as much as it does.
Netgear needs to hire the few more coders and technicians necessary in order to make a decent app and implement the expected features on the Orbi. The Orbi is a flagship product for them. They are a multi-national company worth more than a billion dollars.
If you google the problems that Orbi has had you will see that for a long time wired ethernet backhaul was either not implemented or not working correctly and the USB ports were not functional. There were also many users who experienced connectivity issues for several versions of the firmware. It took Netgear a long time, like more than a year, to fix these issues and turn on these promised features.
Imagine the cost involved in research and development and marketing and advertising for any new router or product being sold at this scale, much less one utilizing new tech like mesh networking.
What kind of dysfunctional corporate bureaucracy must be taking place in Netgear's management for them to highly damage the reputation of one of their flagship products by not giving it the support it needs after launch?
Hire the people you need and stop ruining your own products!
