jasondunn
May 26, 2021Apprentice
Hide SSID option removed from RBR50 firmware 2.7.2.104
I need to temporarily hide the SSID of my 5Ghz network, but the option to do so appears to have been removed. I'm under Advanced > Setup > Wireless Setup. Wasn't it here previously? Did they move it ...
- May 26, 2021
You want the Wireless Setup under "Advanced Setup" at the bottom of the menu.
CrimpOn
May 26, 2021Guru - Experienced User
jasondunn wrote:I need to temporarily hide the SSID of my 5Ghz network, but the option to do so appears to have been removed. I'm under Advanced > Setup > Wireless Setup. Wasn't it here previously? Did they move it someplace else?
That is indeed where it is. (see attached image)
p.s. Images that are included "in-line" using the Photos icon in the menu bar do not appear to other users until they are approved by a forum moderator. There are not many moderators, so this can take hours (or days?)
Images that are "attached" using the Browse... button below are visible immediately.
- jasondunnMay 26, 2021Apprentice
I appreciate the fast response, but mine looks nothing like yours - hence my confusion, and that's why I posted here. So if I'm on the latest firmware (2.7.2.104) and I have none of those options - in fact it's IDENTICAL to the basic wireless settings - what do I do?
- FURRYe38May 26, 2021Guru - Experienced User
What browser are you using? Try a different browser?
I've tried accesing this part of the router in Chrome, Edge, and Safari on my Mac. I've also tried Chrome on my PC. I've attached the screenshot here, hopefully it works this time.
I haven't factory reset the router in a while and don't particularly want to, but if that's a reccomendated solution to this issue or not seeing settings where they should be, I'll do it.
- CrimpOnMay 26, 2021Guru - Experienced User
jasondunn wrote:I appreciate the fast response, but mine looks nothing like yours - hence my confusion, and that's why I posted here. So if I'm on the latest firmware (2.7.2.104) and I have none of those options - in fact it's IDENTICAL to the basic wireless settings - what do I do?
I also have the latest firmware. Can you attach that image?
It would be helpful to know which device requires this much effort to connect. I have a whole box full of devices which scream out MUST HAVE 2.4G WiFi and all connected to Orbi with my smartphone connected at 5G. In the last year, I think only two devices required the "stop broadcasting SSID" procedure.
