wuyongzheng
Sep 20, 2020Guide
High LAN latency with ORBI Mesh network
Problem: The internet speed of both my computers are quite fast (200Mbps, 5 ms latency), but the LAN speed between them are slow (10Mbps, 100ms latency) My network setup: * RBR20: One router & o...
Mstrbig
Sep 20, 2020Master
Who is your ISP and what equipment did they provide?
What is the current firmware on your Orbi device?
What device is your Orbi router connected to?
Did you reboot your ISP modem/router, before starting the Orbi router install?
Have you changed the network cable connected from the ISP device to your Orbi router?
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
wuyongzheng
Sep 22, 2020Guide
I have changed the router setting as you suggested (see screenshot), but the problem remains.
