wuyongzheng
Sep 20, 2020Guide
High LAN latency with ORBI Mesh network
Problem: The internet speed of both my computers are quite fast (200Mbps, 5 ms latency), but the LAN speed between them are slow (10Mbps, 100ms latency) My network setup: * RBR20: One router & o...
Mstrbig
Sep 22, 2020Master
What is your CTS/RTS Threshold setting?
wuyongzheng
Sep 22, 2020Guide
CTS/RTS Threshold for both 2.4 and 5GHz are the default, 2347.
- MstrbigSep 22, 2020Master
wuyongzheng wrote:CTS/RTS Threshold for both 2.4 and 5GHz are the default, 2347.
2347 is set to bypass. You could try lowering the setting to see if it helps.
I played with mine and found half that increased my speed.
I just ran a ping on several internal 192.168.1.x IP addresses and all showed 1ms.
I pinged my 2 ISP DNS server IP addresses and got between 30 and 50ms.
What cabling are you using to connect your Orbi router to the ISP device, and if any to the satellites?
- wuyongzhengSep 22, 2020Guide
Ping from my Linux computer to ISP's DNS server: 6ms
Ping from my Windows computer to ISP's DNS server: 5ms
Ping from Windows to Linux: 100ms (with weird gradually growth)
SSH from Windows to Linux: feels very laggy
In short: Internet is fast, LAN is slow. I don't think the modem or the cable between the modem and the router matter.
- vikrantlFeb 01, 2021AspirantSamr problem with new ax4300 indtallation yesterday.
High ping latency from pc to router.
Netgear, any solution??
