Gellie
Jan 25, 2020Aspirant
HiRez music streaming problem
So in the last day or so ive been having intermitent problems streaming HiRez music from my Squeezbox touch. I have been experiancing buffering problems. The folks on the Squeezbox forms insist its a...
Jan 25, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Gellie
Thanks. How do I perform a factory reset and setup?
- FURRYe38Jan 25, 2020Guru - Experienced User
Two ways, by entering the RBRs web page and selecting ERASE under Administration/Backup Settings or by pressing the reset button in back of the RBR/RBS for 15 seconds then release. Walk thru the setup wizard and be sure to write down important information for safe keeping.
