mlzemina's avatar
Jul 17, 2018
Home Network Orbi (CBR40) DDNS (NO-IP) now unable to Chrome Remote from work
I was previously able to remote to my home computer (home network is with an ORbi CBR40 router and ) from work using Chrome Remote Desktop. I added a NAS (Synology DS212j) and setup DDNS (with NO-IP) on my home network. Now I am unable to remote back in. What must I configure to allow remoting back into my home network from work?
  • I'm going to go another route. So it is OK to close this.
  • FURRYe38's avatar
    Do you have the RBR40 or CBK40?
    What is the Mfr and model# of the ISP modem your currently using?
    • mlzemina's avatar
      mlzemina
      Guide
  • FURRYe38's avatar
    OK, next time, please be more accurate and detailed on what your using. Helps us help you out.
    Good Luck.
