Ggogo2368
Dec 19, 2019Aspirant
Home network security issues
Need help with a lot of issues on my home network. Using the Orbi RBR50 with one satellite and the Orbi outdoor extender. I have contacted Gearhead support numerous times without resolution (do not be...
Jetdrive
Dec 19, 2019Luminary
If you really believe all your computer are infected and being controlled, you should shut all of them down and disconncect them from the network. Then take one of them and wipe the hard drive and re-install your Operating System (Windows or Mac). If that computer now behaves normally then you know that it was some sort of malware or virus. If the computer still has problems as you described, it is not compromised.
